Hello
I am hoping somebody could give me a bit of information regarding insulation resistance testing.
My query is really regarding insulation testing when PAT testing i am experimenting using a Low resistance ohmeter with a Kewtech PAT adaptor
My understanding is that you apply a voltage of 500v to an appliance(reduced to 250v if 500v would damage the appliance) you then get a reading on the tester the higher the better my tester is giving me a greater than 999M Ohms on appliances i have tested within my home.
My main question is what would cause the readings to be low is it just the insulation deteriating or can there be other faults? if so what are they and secondly could i simulate a fault using a length of cable with a lamp on the end to give me a better understanding.
Thanks for your time.
Ricky
Ricky
