Extending an electrical lighting cable in porch
16 Dec 2018
I need to extend some 1.5mm twin and earth.
The cable is under my porch so shouldn't get wet and will be inside some mini trunking. Can you please tell me the best way of doing this? Ideally, the join needs to be as small as possible so fits inside the trunking.
I've seen these Wago connectors - https://www.tlc-direct.co.uk/Products/WA413.html
Would these be suitable for outdoor/under a concrete roof, inside trunking? I could always wrap them in tape as a precaution.
Better to use the red crimps. The earth wire in 1.5mm cable is only 1mm, and the blue crimps are too big for that.
https://www.screwfix.com/p/insulated-red-0-5-1-5mm-crimp-butt-100-pack/94616
If you use those crimps you will need to buy a special Ratchet crimp tool.
https://www.screwfix.com/p/ratchet-crimping-tool-1-0-10mm/96561
Easier to use these connectors. https://www.screwfix.com/p/ideal-32a-2-way-push-wire-connector-100-pack/72727
Stagger the joins so they arent all in the same place in the trunking.
Thanks, seems I have some options then. I think I may be favouring the butt connectors as they should be slimmer and I can also shrink-wrap as a precaution.
I just need to confirm...... I've always thought of those butt connections as being the used for speaker wires etc. Can these be used for mains electrics?
Those insulated butt crimps are really meant for stranded cable. T&E Have solid conductors. They should not be confused with the weedy auto crimps that use an equally weedy hand crimp.
really, the push connector won’t take up any more space and sleeving wouldn’t be needed, if I’m they are in mini trunking as you have described. Think you are making a large hill out of a molehill.
Yes, I do have a habit of doing that :D. I will go for the push connection option.
Thanks again for your input both of you.
Nonsense
The crimp onto single solid conductors has to be made with the correct crimp tool if the joint is to be reliable. If there is any void in the joint then over time the copper will change shape and migrate into the void(s). The pressure of the tube onto the copper will be reduced and the joint will begin to fail.
Good crimp ............. bad joint
In my opinion the best way is to solder the extension and cover with self amalgamating tape.
