Extending an electrical lighting cable in porch
You want a hot and powerful enough iron that you can complete the joint quickly and thus minimize heating of the cable..
For a joint that size I would certainly want more length than is shown in that photo. I've certainly had times when I had to re-do a joint because I accidentally shrunk the heatshrink while soldering the joint.
by being slid into place afterwards.
The first conductor can be soldered and the sleeve, out of the way on the cable sheath can then slid onto and shrunk around that conductor.
How do you get the sleeve onto the second conductor ?
How does the heat shrink not shrink with the heat of the soldering,
Is that photo intended as a serious way to make a soldered inline joint?
That is a very poor way to do it. I always firmly twist them then solder. To improve flexibility of the joint, it can just be soldered at the ends, no solder in the centre.
Yes. Mechanical "strength" is provided by the way the copper is hooked together and the "connectivity" of the joint is provided by the solder.
My opinion is any joint should be protected from being flexed
Sorry, we will have to disagree on that particular joint, the mechanical strength is quite limited, when compared to a well twisted and soldered.
Of course, but sometimes some flexing cannot be avoided. Too rigid a joint and it can be its own worst enemy.
The joint should be mechanically sound before any solder is applied - that is when you tug at the two conductors, it should not separate.
That was what I was always taught, but I would not expect Bernard's simply hook joint to survive a slight tug.
I would have assumed it would be twisted after the hook, but who knows.
You have to strip enough sheath that you can put the sleeving for the individual conductors on an individual conductor without accidentally shrinking it during soldering.
This is obviously a balancing act because on the one hand you don't want to make the joint longer than nessacery but on the other hand accidentally shrinking the sleeve can be a PITA.
