An isolator is just another potential weak point. As stated, they are useful for a CU change, but getting the fuse pulled is not that difficult to arrange.
Sure - you're merely repeating RF's view.
Is this thread restricted to answers from RF. (Scousespark)
However, as I've said, if the alternative under consideration to to have Henley(s), the the number of joints is the same, and the chances of the mechanism of a (very rarely operated) isolator 'failing' is surely vanishingly small.
It may be small, but an isolator can fail.
If a homeowner wants an additional CU, then I would say that is the time to fit a henley block.
If either are already fitted, I have no issue using them on jobs.
(Scousespark)
I am puzzled as to why a diyer would 'often' need to open up a CU to access the earth/neutral bars.
I don't think anyone said anything about 'often' - and, in any event, it's far more likely that an electrician (rather than a DIYer) would be doing things within a CU. However, as I said/asked (and this applies just as much to electricians as DIYers)...
In the post I quoted, you stated that
one often has to have ones hands very close to them when doing things with neutral and/or earth bars - I was questioning why you would need to often work in a CU. I have rewired my current home once and that is the only time I have had to work in the CU. (Scousespark)
Kind Regards, John
