- Joined
- 20 Apr 2014
- Messages
- 2,467
- Reaction score
- 0
- Country
I am extending the ring circuit in my house by running two pairs of wires from an existing socket. To do this, I plan to terminate one of the two new pairs, and one of the existing pairs, on the existing plug socket terminals. For the other pair of (one new and one old) cables, I was thinking of tying them together (using separate terminals/connectors) within the mounting box for the socket. It all seems fine in theory, but is this actually a dumb/dangerous thing to do? I am wondering whether "cramming" the mounting box like this is likely to lead to problems with heat for example.
I want to avoid using a spur as I plan to add an additional 3 points and I believe that you shouldn't add more than one socket on a spur. The option of taking the other "end" of the ring circuit from the next socket on the ring is also out for me because of the current state of the house (would require exploring walls, pulling up floorboards, etc., which is a lot of work that I'd much rather avoid).
Any advice would be greatly appreciated.
Thanks.
Thanks.
