Black twinwall, such as this:Others here can probably advise you what sort of ducting would be best.
http://www.drainageonline.co.uk/Ducting/Black-Twinwall-Duct-x-50m-coil.htm
That is what BAS suggested, and it clearly would make sense as a reason for the two cables (or more cores in one cable). However, I'm a bit confused, since it seems that the plan is for these cable(s) to be supplied from an existing outdoor socket.... Sounds as if you're wanting to control lights and power from the house ....
Unless, as has been mentioned, you used some sort of wireless switches or suchlike, you would not be able to control the lights (alone) from inside the house if the supply to them originated from an outdoor socket.I don’t think they will be able to be controlled from the house? But could be wrong? There is a double outdoor socket just outside the kitchen door, he said he would ‘spur’ off that.
Ah, I slightly misunderstood - I thought you were talking only about lighting (and power) in the shed. If there is to be a feed for outside lighting, then that probably would need a second cable, since it would probably have to go to somewhere other than the shed - but you would still have the issue/problem of how you switch those lights - maybe an outdoor switch near the existing outdoor socket?I told him we will need outdoor lighting, shed power & lighting, a socket for lawn mower ....
That's obviously what I suggested. 2.5mm² cable is definitely not at all 'beefy', particularly given the relatively long run you are talking about.... but would like to put in a beefy cable in case we need more in the future eg home office sort of thing.
As above, I imagine that the outside lighting cable would need to go somewhere other than to the shed. In that case, it could not really share (at least not all of) the duct going to the shed. However, there's not a strong argument for putting the lighting cable in a duct - directly-buried SWA would probably suffice.I presume the duct can have 2 cables running inside if that still needs to be the case in the future?
As I said before, that sounds more than adequate.I will ask the guys to dig the trench say 700mm & use the yellow warning tape further up. Will this suffice?
What sort of ducting is required for external cable?
There's a lot of 'assuming' (guessing) involved in that statement, I reckon.Presumably via a FCU ...
