Is it on its own circuit or a spur off a ring or part of a radial?
What rating is the MCB that switches it off?
I'll join in the asking of questions:
Winston, how do you KNOW that it would not be feasible to take a larger supply to that point on the external wall of the house in the future in order to supply a larger load in the garden, and therefore how do you KNOW that there is no point in having a larger external cable installed now?
You're welcome. I hope it all goes well.^^ I agree I would like to future proof as much as is reasonable/possible. So the ducting was a great suggestion! As clearly it was not as simple as putting a ‘big’ cable as I first imagined! Thank you
You aren't.
But not everybody is as short-sighted as you.
Some people think that future proofing is a valid concept.
Indeed.
So stop predicting that the OP will never need a larger cable, and stop guessing that there is no point in him thinking about whether to install a larger one now to minimise the risks of it becoming useless in the future.
Except there wasn't any.pointless abuse removed
Sunshine - you should PM Winston, as you need to get his contact details as you've got to get him to sign this declaration on an EIC:
I being the person responsible for the design of the electrical installation (as indicated by my signature below), particulars of which are described above, having exercised reasonable skill and care when carrying out the design hereby CERTIFY that the said work for which I have been responsible is to the best of my knowledge and belief in accordance with BS 7671:2008, amended to 2015 except for the departures, if any, detailed as follows:
You also need him to put some sort of warranty in place to cover the costs of replacing the cable if it turns out not to be large enough.
For what it's worth, and particularly since you're about to have landscaping done, I would personally either put in a duct or else use SWA appreciably larger than 2.5mm² - since it's amazing how many people come fairly soon to think of a reason why the need significantly more electricity in their garden/shed/whatever than they originally thought would ever be needed!
Kind Regards, John
Hundreds?
How long is the garden?
True, if you want to be able to switch the lights on from the house end.
4-core cable is an alternative. Or 5, if you think you might want two sets of lights, or lights and a water feature pump.
As you quoted, what I said was about "what I would personally do". Even if you chose to regard that as 'advice', I don't think that anyone could seriously regard "... put in a duct or else use SWA appreciably larger than 2.5mm² " as being meaningful 'design' - so I think that a lot more actual design work would need to be done before the question of any "signing off of a design" arose (and the same goes for BAS's comment about "4-core or 5-core" cable that you have asked the same question about).Just wondering why BAS has not jumped up to ask how you are going to sign of the design? Or is that just a Winston requirement?
