thanks ! didn’t see that coming. you walked straight into it lolololololol"tanking is a last resort, and usually the worst and incorrect solution. it creates cold surfaces and stops the natural escape of moisture"
I wonder who said that?
Benny , I think of the late great Benny Hill. When he did "the chase" every episode... builders running around the site . Who will be the slaphead guythey may as well call this the lime render club! some people think the answer for absolutely every thing is lime render or the lack of!
Benny , I think of the late great Benny Hill. When he did "the chase" every episode... builders running around the site . Who will be the slaphead guy![]()
OP,
your original complaint was roughly about humidity its causes and consequences.
You mentioned previous work by a D&T company, and the possible humidity consequences of the sand & cement plinth.
To first get the plinth issue out of the way: the plinth is not a cause of your humidity. Cut the plinth off by 40mm to 50mm from ground contact
and then leave it alone.
The D&T claim of installing a "full length vertical DPC" means what?
You have solid walls - so was a horizontal chemical DPC line installed anywhere on that elevation?
What kind of tanking was installed?
Are the installed air bricks telescopic?
Site inspection might be needed to determine if your re-pointing is adequate? Its, perhaps, sand & cement over an original sand & lime beds and perps? It should be raked out to a min of 20mm.
Condensation creates mould and mould is bad for health esp a child's health. Humidity can damage interior fabric.
You should have a permanent air brick high level vent in the bed room.
Trickle heat & trickle venting often help with condensation.
Timber frames provide better leakage ventilation than PVC windows.
AAMOI: wood frames & chimney stacks (period details) often add value to a property.
A site call: could be its time to remove the tanking back to brick, and then render with a sand & lime render?
Any joist tails landing on that wall are at risk of fungal damage, & need inspecting - maybe use your Endoscope?
thats a dpc , it’s there to protect the underfloor joists from the elements . given the close proximity and damp ground level of the air bricks. it’s as it should be.No idea is the answer to most of @bobasd 's questions unfortunately. I simply don't have any more information other than the D&T survey plan in regards to the works done. On the plus side there is no longer any visible or touch damp on walls internally or externally whatsoever. On the minus side clearly there is still excess moisture attributable to very high and persistent humidity levels, causing persistent condensation and mould growth, and that needs to be addressed. I don't believe any of the walls are single skin, the rear structural wall is ~450mm thick at ground floor level and other walls are > 300m thick. The installed air bricks are definitely NOT telescopic and are modern clay/ceramic style.
A few other factoids;
- The ground floor stopcock is at the end of the entrance hallway accessible from what is currently the bathroom (probably originally Victorian kitchen). No visible damp or leakage in the wall void.
- The large aluminium glass door is a recent addition, and I can share the following WIP shot that shows what looks like a DPM under the floorboards.... really not sure what to make of that.
