Extractor fan -2 core or 3
27 Nov 2007
Hi I am about to replace axial manual pull cord with a non timer Xpelair CF 20,which i want to come on and off with the light switch.The wire from the isolater to the fan is only 2 core,does this need to be 3 core or is that only for timer fans?
the cf20 has a humidistat doesnt it?
if so it will need a permanent feed to work correctly.
you could bridge the terminals to get it going but you bought a humidistat fan so you really want it to work properly.
Yes it does.So does that mean i will need to replace 2 core with three
Right oh ,so that`ll be 3 core from isolater to fan and from ceiling rose to isolater then
Thanks very much,think i`ll still get an expert in to it though.It`s a bit messy at the light as there isn`t a rose ,just a few blocks wrapped in isolating tape.Thank again,nice to have learnt something new
since your profile doesn't say where you are It's common practice round here to do the following with regards to electrics in bathrooms...
PART P.... PART P.... PART P.....
the alteration of circuits in bathrooms and kitchens is notifiable to your LABC before comencing work and a fee is usually payable..
your best bet is to get a registered sparky in.. will cost less than DIY and self notification..
