- Joined
- 22 Jan 2007
- Messages
- 17,471
- Reaction score
- 2,404
- Country
Header cistern, just trying to spread professionalism.Header tank
Mention storage tank or rising main when I was learnin' and you were suitably chastised...
I put a magnet on the T piece and it does stick, it also sticks on the pipe down to the pump and the curve above to where it meets the other T piece. I assume this is where the blockage is? I put the hot water on for a couple minutes and the pipe heating up evenly so i couldnt tell where a blockage may be.Normally a blockage in the pipework where the feed joins at the T piece (blue line). If a magnet is attracted to the area it will point to that.
And read my sig ⇩!
Copper isn't magnetic, but the blockage normally is, sounds like this is the problem.I put a magnet on the T piece and it does stick,
It isn't difficult but if you know your limits, then yes, get someone in. It is the obvious thing to try first.I'm not confident to cut pipes, so i assume the only way is a heating engineer to remove and replace this section?
It's a very common problem. With the pump on the blockage causes water to rise up the feed into the cistern. the water has to go somewhere and it takes the path of least resistance.If its not the mains makeup, ballcock etc, then it simply can't overflow from the primary side, how can it??.
The heating system. It doesn't take much to fill the feed and expansion cistern.Where does it get the water from??
Just before you go, when the heating and pump stops does the water stop dripping/overflowing from the overflow?.Thanks everyone. It seems i have my answer. Time to spend some money!
after a little while yesJust before you go, when the heating and pump stops does the water stop dripping/overflowing from the overflow?.
