Fairy Liquid dosing
30 Dec 2018
Up North
Yep, I've heard you can now buy a new version of Fairy Liquid, which meters the dose that you squirt into the bowl, but I've been experimenting with alternative methods to avoid wastage and cut out the guessing. Those pump bottles, which contain hand-washing soap, deliver just the right amount of Fairy, for a bowl of washing up, with a single press of the pump and no waiting for the liquid to trickle it's way down to the outlet, before squeezing.
So in order to prevent waste by a user using more fairy liquid than they need to they have started using non recyclable squirty tops and made more waste.
While they may be made of recyclable plastic when they have a metal spring in them it prevent them being recycled as easily so they are usually destined for the general waste (hole in the ground).
But hopefully they won't get thrown away so often. Really should incentivise that sort of thing by selling eg a pump bottle for £1.50 and then the exact same bottle without the pump and just a peel-off foil lid for £1, so one can unscrew the pump, transfer to new bottle and throw the old one in the recycling. Perhaps even a squeezy refill pouch using a tenth of the plastic of a new bottle
It'd also be nice if the base of the bottle could have an internal slope to a point that the pump picks up from, so it's not so much of a faff trying to get the last bits of soap out.. but designers clearly can't give us everything?
What I do with the original squirty bottles is...
Put the spout under the running water, filling the bowl, squeeze and suck water into the container. Then swill around and squirt into the bowl.
I just squirt a big load in my hand and rub 'em together.
what?
:whistle:
Yep, that's essentially what I was referring to when I said "faff" - in the context of a pump bottle it's unscrewing the pump, water in the bottle and shake it, perhaps then decant it to the refill, or use it for a few hand washings (much less satisfactory if it's too watery of course)..
TBF I think for stuff like hand soap it's probably reasonable to mix it 50/50 with water anyway, right from the moment of it being a new bottle (something easier to do when refilling) and particuarly when we top up a pump handwash with fairy liquid; one shot of neat FL is way overkill for a handwash
Point being that if the bottle were designed better, a small pocket for the soap to drain into and the pump to pick up from it would all be unnecessary. The other option is just to have a refill process that puts new soap on top of the old.. But they never seem to supply refils in Capri Sun type "squeeze it completely flat to get everything out" type pouches..
It's no great faff, I just do it the once, as the FL is empty to use up the last dregs of liquid in the bottle, before it goes in the recycling bin. It doesn't matter that it is diluted, because it will be diluted in the washing up bowl anyway. The difference now, is that I use the FL bottle, to keep a pump bottle topped up.
This is our setup. We've had that bottle since November 2021.
Just noticed - 825 first dates - just right for Harry. ;)
