M
mysteryman
As it's happening on two loos, there is a common factor, which must be something pulling a vacuum on the sewer. Dynorod?
5. put a piece of hose round the trap so that it vents the drain beyond then leave for the hour that " things happen "Surely, this has to be a process of elimination.
1. take the toilet out, fill with water and watch the level.
2. Stuff drain rods down it, and ensure its not blocked.
if all ok, its not a problem with that specific leg of the drain.
3. if you cracked the lid of the nearby manhole, then its not suction being caused down stream.
4. It must be suction being caused by something else drianing into the same drain from up stream.
so i would hazard a guess as a blockage in the soil vent pipe, something like a bird nest or dead bird..
Its the only possible thing left.
