I've recently been called to a fault on a lighting circuit in a property, when asked if the occupier had done anything differently he told me that all he had done was change the lamps to the eco friendly ones.
I then disconnected all the lamps and when i then tested the circuit the only time i can see that there is a fault is when i test between the live and the neutreal when the neutral is connected into the main neutral bar in the fuseboard. When i then disconnect the cable completly and test between the live and neutral there is no fault showing up at all. But when i then test between the neutral and earth bar it is coming up as a dead short.
So my question is could a neutral to earth fault on another circuit be what is causing the fuse to blow on this lighting circuit when the lamps are in?
