B
Big_Spark
Chicken, they are not designed to be used as anything other than decorative lighting, they are not suitable for use in a bathroom despite the fact they can be used on decking.
It's bad practice to have two different circuits present at the same accessory, as there's the danger that someone might turn one off, and then think it safe to work on the switch, or whatever, not realising there are still live wires there. I don't think it's actually against the regs, but I might be wrong.OK - heres another way around, If i wire the socket into the RING MAIN, can I use one side of the 2 way light switch to operate it or isn't the light switch up to it (Personally, I dont think it is)
Nothing to do with current - I thought that the mere presence of BS1363 socket outlets on lighting circuits was verboten.plugwash said:how is putting a 13A socket on a lighting cuircuit any worse than using a 5A rated mains extention lead?!
Err - that's just what I said:plugwash said:you cannot just take from a ring to a lightswitch either you must fuse it down first
I said:2) Find an alternative PSU which does have a plug and flying lead, remove the plug and wire that via an FCU on the lighting circuit
Why wouldn't a 12V light with an IP suitable for outdoors be OK for a bathroom?FWL_Engineer said:Chicken, they are not designed to be used as anything other than decorative lighting, they are not suitable for use in a bathroom despite the fact they can be used on decking.
ban-all-sheds said:Why wouldn't a 12V light with an IP suitable for outdoors be OK for a bathroom?
Includes 4x15mm LED fittings each with 5m cable 12V indoor transformer 6 way junction box with 10m cable.
White LEDs.
Further, the BS that coveres these lights does so on the premise that they will be used a "decorative light for infrequent use"
securespark said:FWL
I have installed a raft of external SELV gear (mostly lighting) that has an indoor transformer. It sounds crazy, but it's true. Searchlight do a lot of stuff where the tx is not IP rated for ext use. They supply extension leads to make the secondary cable longer!!
Chicken said:why not?
