Yes it is. Downlights and insulation are not a good combination. The general minimum requirement is 100mm clearance all around the the light itself and a similar distance if you are using transformers.With regard to the void between floor and ceiling. Both floor and ceiling are being completely replaced with plasterboard ceiling and chipboard floor. The void is 7" and I am buying downlighters which are 105 mm which should give me 70mm clearance. Hopefully this should be enough. I was going to insulate the floor with with rockwool.
Is this a problem?
But you need to look at the instructions and comply with them.
I replaced two transformers this week that had gone a shrivelled chocolate brown after being placed under some insulation.
However, for the Halers 2 mentioned above the gap is 50mm above and 75 mm either side of the light unit - the driver is built in.
http://www.downlightsdirect.co.uk/h...ownlight-brushed-aluminium-natural-white.html
For example instructions.
