So if your doing something with the kitchen plumbing you can turn it off, then the wife and kids can still have a shower when you **** it up
Plumbing is overhyped, by overpriced plumbers.
Anyone can flash a joint, that's the easy bit if you do the prep right.
Buy the book and stop guessing then...
It's a kitchen; when I moved in it rather fortuitously had the two traditional options of water temperature provided, each through a 15mm copper pipe (heavily referencing similar arrangements in other kitchens). Unsurprisingly, and with no assistance from any regs booklet, the old arrangement worked fine with the last sink unit, so it'll work fine with a quite minor variation in pipe positions on the next.
Go gaslight someone else.
still need to take a schit and a hot shower
I try to avoid compression joints generally, but in inaccessible areas? Always.
... Preferably, not with the same water!
Quoting myself above, but, very relevant to this thread!
You’ve lost me now. I thought you were fitting a new kitchen unit and sink to some existing copper pipe.
Thank you but I'm aware of that basic issue. My cholera jabs are current, as it happens.
