- Joined
- 11 Jan 2004
- Messages
- 43,616
- Reaction score
- 2,806
- Country
What starter do you use with this?
I always use S2's on an ~20w fitting. I find they strike much better. I think they're 4-22W as opposed to 4-65w. Had some lay in modulars recently that standard FSU starters wouldn't strike. S2's cured the problem.Just asking as I sold one on ebay and the chap is using a Philips S10, 4-65W starter. He says the choke is not working but he says that the starter is glowing when powered up.
Surely that means the choke is OK?
I have always used them on lay in modulars, and to the best of my recollection, they have always only ever had two starters. Maybe I've been using them wrong! But they've never let me down. I've got S10s in the van too, but they get much less use.I always use S2's on an ~20w fitting. I find they strike much better. I think they're 4-22W as opposed to 4-65w. Had some lay in modulars recently that standard FSU starters wouldn't strike. S2's cured the problem.
Are you sure, an S2 is a series starter it only does a single 20 watt tube running at 110volt
Its mainly for 2 series wired 20 watt tubes connected to a single 40 watt choke.
3 tube lay in modules would normally use 2 S2 starters and 1 FSU
4 tube lay in modules would normally use 4 s2 starters
SS, do you know what he is using the choke for, its highly likely hes using the choke for the wrong application, or hes a freind of "Winston" and reusing an old starter.
That would be extreme watching it blow upThere are figures sometimes available that list the current that will flow if the ballast is connected across live and neutral. Checking the current with the datasheet would confirm if it is working correctly, but this is rather extreme. I would try a new starter first, followed by a new tube.
