Become accustomed to delays; the U.K. Building industry has nowhere near the same level of interest and enthusiasm for building your house, as you do. Forgive yourself too. I self built, and by that I mean I planned it, financed it and picked up the tools for every single job except erecting the timber frame, some electrics, some plumbing and most the flooring/decorating (too busy, and these were jobs that the control freak in me was happy to hand off).. the other style of self building ("man who works in office and doesn't know the thick end of a cordless from the thin, arranges tradesmen to build his house") is what I refer to as self-project-managed. It took a lot longer than I expected, because everything was done right rather than slapdash. Towards the end (I'm not there yet) I hired a guy to help board and skim the loft, who turned out to be brilliant (he went on to tile 2 bathrooms too). He watched in amazement as I was fitting an airtight vapour control membrane around a roof truss that was part of the pre existing building. Took an hour. "Whatcha doing that for?" - I explained about air changes per hour, part L, heating demand of a 280sqm house with a 50% glass roof... and how an air source heat pump wouldn't be able to do it if there was a gale blowing through the place..
"well, I've never seen that in all my years. You'd have been finished 6 months ago if you hadn't got onto all that fookin *******s"
I too thought it would take a year. It should, in fact. There's a local road where the houses are typically bungalows that are gobbled up into massive houses. Every day I passed one being built, and no word of a lie, they kicked the crap out of that place in 6 months. That's what budget and motivated trades do for you. Plus having an existing building that was serviced probably helped as the admin for these these really drags. no idea what their budget was, but I recall a Restoration Man episode where an last house was converted, and the conversation went "and how are you for time and budget?" "On time and on budget" "and what is your budget?" "Six hundred and fifty thousand pounds"
Yeah. That's why.
4 years after buying the site, me doing 4 ten hour days in the office, 2 ten hour days on site and one day with the family(grown since I started) I'm near enough to move in.
Next time I build a house I will:
- Enjoy drawing it myself, not enjoy battling the planners
- Not use a self build mortgage, because the financiers are the biggest millstone and the most considerable thieves - this being my first house I had no sizeable equity in anything else to mortgage
- Jobs I'll do myself: foundations, slab, UFH, insulating, air tightness, electrics, plumbing, ventilation, heating system, window install, carpentry, tiling
- Jobs I'll get someone else to do: erect the frame (one man can't do it fast enough to make it worth it), plasterboarding and skimming (heavy, can't do it fast enough), roofing, decorating (boring)
- Be retired and bored and able to give more time, less intensely. Right now, I'm only 35 so I can cope with it, but it's tired me out.
Windows not fitting is easily avoided. All of mine fit, but every hole was measured 5 times and the window schedule they sent through needed 14 revisions. They still managed to **** it up and build one set of bifolds so they opened the wrong way, but that was easy enough to solve. When the company do a window schedule, ensure the document bears the overall size of the frame plus any sill, and if any frames are composite (bolted together-some of mine were 4m high and in 3 parts. They omitted the 12mm joint bars from the first drawing) ensure the dimensions for the whole include any jointing strips or bars.
Critically, when they send you a doc with 10 windows in and you write back saying "window 7 should be 2130 high, not 2310 high" and they send you a new doc back, do not assume they only changed that window (logical), check them ALL again. Check everything; check that they didn't accidentally delete the sill, or change the handles for gold ones when the rest are chrome etc. They won't want to use your carefully prepared schedule; they'll hand type it all into their own software, feck it up doing so and you'll need to check it all carefully
The best thing to do when it comes to windows is to make up some squares out of slate batten or other rough cheap wood that are the exact size you want the holes to be (tack a strip of 10mm marine ply to two edges) and dead square, and fix them in place (attach bottom to wall and top to a long batten that slopes down to the slab) as the brickies are building the walls. Get the brickies to build to them, then take em out and remove the ply(it's tolerance for the frame), and give them to the window company along with a set of measurements. You might think the 3 hours or so it'll take to make these frames is a waste of time, but every brickie I've dealt with has appreciated having something to build to
Of course, if you're planning on having the windows on site before the walls go up(not a bad idea) then you have your templates. I'd still attach 10mm to two sides so that you've got your 5mm gap all round to foam up; making that gap too small will make it difficult to foam and seal
For cost compare, my window schedule was:
Two 1.2mx4m, casements with floating mullion and central opaque panel
Two semi circle arches 4m diameter, one with tilt n turn, pvc
Two fixed nonopening panes, 1.6m x 2.5m
One bifolding set 4mx2.5m
Two bifolding set 4mx2m
Two bifolding set 3mx2m
Two glazed doors 1mx2.5m
Twenty roof windows, 0.6mx1.8m
25k supply only, all aluminium except the arches. Triple glazing quote was 45k. I'll make some external insulated shutters for the saving, if the heating bill is too high
1.8k fitting for everything bar the roof windows (self fit)
I too was puzzled about the price hike for TG. I see 20% as reasonable but not 50. Yes, profiles have to be bigger, and theyre a lot heavier so hinges need updating etc, but I think a lot of it is market forces, low demand etc. Have you considered European suppliers? There's a thread about TG suppliers on green building forum, I think you're a member
And that's how jewsons stay in business, and run huge branches over staffed and unable to budge on price much. I didn't get a lot from jewsons, thou Wickes and screwfix have had thousands out of me, chiefly because I appreciated the convenience of their opening hours, the fact that the missus can see before she buys, and their customer service and returns policies are great - buying 5 of everything and taking 3 back months later is very handy. Plus, screwfixes own brand stuff is good quality gear and on par price wise with eBay alternatives
Sign up for a Wickes trade card to get 10% off. There was no verification that I was actually a tradesman. I bought about 100 plumbing fittings one day in screwfix, and the manager said "are you a plumber?"
"I am! How did you guess"
"Want a trade card?"
"Go on then"
Discount varies, sometimes it's only a few percent, yet my RCBOs were 23% off a tenner to start with. That's cheap.
You can use seconds insulation for more than you think. I've ordered thousands worth off them and it's nearly all been flat and straight enough to use. Their mixed pallets are priced randomly so be sure to work out the per cubic metre cost of the kingspan on the pallet. Real kingspan is about 100 quid a cube. My seconds was between 30 and 60, but some pallets are priced at 150+ so be careful.. you can also get it for nothing, if you're prepared to hire an artic: https://www.secondsandco.co.uk/product-page/free-pallets-of-offcuts-collection-only-from-ld8
Gotta love how those guys write their stock descriptions
Yeah. That's why.
I know there will windows not fitting (seems to happen a lot on the self build forums) and so on - practical real things
Infuriating isn't it? That's what you get with a self build mortgage, and you pay double interest and have to buy an insurance policy that will build it if you don't, so they can sell it and make a fortune off robbing you of your life savings. "Because self build is more risky". ****s.Today I am working again on another spreadsheet - this time for the building society who want you to tease out the exact costs
(mostly they used Jewsons)
"Go on then"
