If a socket outlet is fed from an FCU with a 13amp fuse, how many 13amp sockets can be fed from it, since I have seen some diagrams showing a fused spur feeding let's say, one single outlet and then from that one double-is this correct or does it exceed the what is allowed?-since 13amps wont give much capacity.
Also, it says in the onsite guide 1.5mm cable may be used though I'm sure I heard someone saying "no spur of any kind should be 1.5"
Could somebody explain what is/isn't right please?
Many Thanks
Many Thanks
