Fair enough.I think ill just trial connecting the fuse up properly ...
They won't... and seeing if the saws melt the fuse.
Fair enough. If you connect them to the load side of the fuse, you can (per regs) have as many sockets as you like - although, of course, the 'theoretical maximum' you could (should) draw across all the sockets would be 13AI want to add a socket on the other side of the garage but for low wattage stuff, so itl look like this:
Fair enough - but, as above, that's not going to happen 9with your presently envisged loads). Of couyrse, if, in the future, you decide that you do want to service appreciably greater loads, then you would need to extend the ring.If this fails and the fuse blows then ill extend the ring.
I hope all goes well - which I'm sure itr will.
Kindest Regards, John
