I'm having some building work done which means a gas pipe needs to be relocated to the other side of a wall that has a run of cables along it.
Can pipe and cable be run together with less than 25mm separation if the gas pipe is enclosed in something like a PCV waste pipe or the cable is run in PVC conduit or trunking?
