rockhopper69";p="1856088 said:I am competent . and also a registered gas installer ( not that holding gas tickets makes you competent ! )
ive come across some right plonkers holding tickets
i would consider a qualified gas engineer asking if such a fitting as a 1" x 28mm meter tail has been invented (and if available where to get one) as incompetant
Gas man , no disresect but i did say i can correctly size pipe ! . can you not read. ?
Kirk gas in all my time working with gas ive never stepped up in pipe size , ive always thought it was a no no , is it not ?. Like i said ive had very little experience in working around gas meters .ie removing them and fitting them .so wasnt sure if stepping up in gas pipe size from the meter tail was good sound practice , I personally would never of done it ide of thought it was a restriction regardless of downstream pipe being bigger diametre.
can you please explain to me how it makes me incompetant if i didnt know if a fiting was available for a u6 meter ? or if its ok to step up in size from them ?
If your correct in what you say i hold my hands up .
