Hi All
I'm currently having the existing basement of my Edwardian semi-detached property made more 'user friendly' via the installation of a proprietary (Triton) cavity drain system, plaster board/plaster walls & ceilings & a wooden floor. One of the main tasks is to 'hide' the myriad of existing services (water, electric, central heating & gas) which have been installed, extended & de-commissioned on, over & through the basement walls & ceilings over the last 100 years behind the new walls & ceiling.
When we bought the property the gas pipe that runs between the meter & the boiler (28mm dia @ circa 6 metres long) was installed directly below the existing lath & plaster ceiling with pipe clips. Having removed the old ceiling the plan now is to move this pipe up into the void between the new ceiling & the floor above however...
In order to do this the builder is proposing to run the pipe through notches in the joists such that the gas pipe would sit just above the new plasterboard. I realise that notching the bottom of joists is not permitted by the building codes & having a gas pipe almost touching a plaster ceiling doesn't feel quite right to me however the builder tells me that's how its 'always done' for basement conversions such as this. To be fair to him the 'conventional' way of doing this - removing the floorboards & installing the pipe from above - is totally impractical & the only other viable option I can see would be to drill the joists & use a (very) flexible 28mm dia gas pipe (the joists are a mix of 6"x3" & 6"x2" at about 350mm centres). Are such gas pipe available? Do I have any other options? Any advice would be much appreciated.
