Read your contract with them. Anything mentioning gas supply pipes read very carefully. Then get on the phone to them.
so blindingly obvious to do that but perhaps not! LOLHas anyone actually bothered to measure the gas pressure at the meter outlet?
That would be my starting point.
For the rest of the week...Then go to the cafe for the rest of the day.
pressure with nothing on - 23mbarHas anyone actually bothered to measure the gas pressure at the meter outlet?
Never seen or heard of a cracked plate heat exchanger, pinholed yesCracked plate resulting in a dangerous do not use sounds very strange
yep and wouldnt be a turn offNever seen or heard of a cracked plate heat exchanger, pinholed yes
with those faults they could quite easily have tested the pressures before hand,Apologies, it was the insulation panel that was cracked. The combustion seal was also in poor condition.
@oldduffer it's an older house, no new builds close by
It could be either, so wrong to assume. Although some say operating pressure at the boiler is the burner pressure (which not all combi‘s have).they have listed the standing as 21 and operating at 20, assuming mb, Would I be correct in saying that this will be the pressure at the meter itself as opposed to the boiler?
if they have listed standing and operating as 21 and 20 then this would suggest they tested it working. possibly just at meter ,But possibly just ticking boxesAsked for a copy of the pre install survey, should they have tested the pressure at the boiler and potentially been able to pick up on the low pressure?
