Someone told me "Yellow Orca" But i've never seen a yellow Killer whale
No, it isn't.Norcon said:As for the low porosity thats overcome by lapping more tape around the threads.
Well as you can't tell the difference between high porosity and low porosity, there isn't much point explaining.If it has low porosity then how come I have used the stuff on industrial refrigeration systems pressurised to 30 bar in some cases and NO leaks ?. EVER !.
Can Onetap now have an explaination why we cant use insulation tape to seal threads
Onetap yoy are good at quoting so try quoting where i said it joints un screwed themselves .
The guy who said explode would have been have been referring to what could happen indirectly. When you have worked on the gas emergency side and been to as many leaks on joints on normal PTFE that have loosened off as the tape within deteriorated and left serious leaks perhaps you would not find his comments so funny
That would make it thicker (ie more like you)
But just as dense as ever (Exacltly like you)
This is a gas issue afterall isnt it?
Dave
can you not get your head around what is tight initially
Norcon fek off till you have a clue what your on about
