Naz, what benefit does 12 wraps of PTFE have on a thread?
Please I want to learn something.
GirthNaz, what benefit does 12 wraps of PTFE have?
ffs he is clearly talking about the threads of the rad valve tail
Yes, I was wondering this too. Naz can you clear this up for us? Are you talking about PTFEing the compression nut thread or the tail that actually screws into the hole in the radiator?
The 12 wraps ptfe is for the thread on the tail going into the rad.
You mean the "insert" you pillock.
City & Guilds my backside.
Hey Naz , wrapping tape around the threads of a compression fitting don't do jack , see this so many times.
Can you explain what the PTFE actually does when wrapping around the thread for making a water tight joint?
Its simply a "good practice" i was taught at college by my plumbing lecturers who worked in this field for many years. Ive taken it on board and always done this. As i've seen many joints in customers homes with PTFE tape on them, ive just accepted this as the norm.
Although i do generally wrap a couple of turns of ptfe on most threads.
boss white and hemp - cleaned off with a hacksaw blade Loctite , Schmoctite If Nadz said he used a wrench , you lot would moan that it`s a spanner[Went to a radiator job last week where the gas safe installer had done this, with the ptfe tape clearly visible on the radiator valve joints. looked terrible.
threaded joint`s ptfe yes
but not thread on a compresion joint
as has pointed out it does jack
