I posted this questions direct to Gas Safe:
"May I legally disconnect and re-connect my gas hob using a bayonet fitting (with flexi hose) without needing a Gas Safe Engineer?"
I received this most helpful response:
"Thank you for your enquiry.
The debate around who is permitted to disconnect and reconnect a self-sealing connector (or bayonet fitting) serving a gas cooker has led to different opinions being offered e.g. where appliances are disconnected and reconnected by other trades as part of a property refurbishment, or by a removal and/or storage company.
The primary legislation relevant to the safe installation, maintenance and use of gas systems and appliances is the Gas Safety (Installation and Use) Regulations (GSIUR).
This legislation, along with the Approved Code of Practice and Guidance – Safety in the installation and use of gas systems and appliances (ACoP) – published by the Health and Safety Executive (HSE), describes what is considered ‘work in relation to a gas fitting’ (‘gas work’) and provides guidance on what needs to be considered when disconnecting and/or reconnecting any self-sealing appliance connector (bayonet).
Where a gas cooker is installed for the first time or repositioned permanently, it is considered ‘gas work’ and must therefore be carried out by a Gas Safe registered engineer who holds the appropriate proof of competence.
The disconnection/reconnection (at the same location) of a self-sealing appliance connector following installation is not deemed ‘gas work’ and therefore may be carried out by a non-registered person(s), for example, when a home owner temporarily removes the cooker when cleaning. However, whenever any person who is at work, disconnects or re-connects a self-sealing connector they must be competent to a level that will ensure that the installation is not allowing gas to escape.
In most cases when the cooker hose is disconnected from the self-sealing connector, there will be a residual smell of gas. Therefore, it is strongly recommended that as a minimum, an appropriate leak detection fluid (LDF) or gas detector is used to confirm that there is no gas escaping from the fitting. "
Regards
ANDREW
Regards
ANDREW
