Hi can some one please help me.I have just installed a 30kwatt combi boiler and all see to be ok.Got a corgi man to check and test it .But he said the gas supply was to small and needs to be run in 28mm pipe.I hae used 22mm pipe. i did my sums and worked out30kwatt boiller = 0,o3mwatts 0,03divided by 38.7mj/m3 =0,0007751m3/s and so max pipe runfrom charts =20mts .My pipe run is12mts +6fittings = 3.6 mts so a total off 15.6mts is this right and if i have to run a new 28mm run from the meter can the last 3.5mts be 22mm as this part is under the floor and tiled over. many thanks Joe
