Its between -1 and -3 outside here at the moment, so I'm guessing its working pretty hard, but still, what I dont understand is how the old boiler can have been using so much less, I guess this must just be because it was a lot smaller and hence more closely matched to our current system.
What does everyone think about me turning the water stat down and only switching the water on when I need to use it? Not sure what setting to put the water on though as thought the "e" mode was meant to be the most efficient?
Are you really comparing apples with apples when you say it's gone from 6 to 14? Is it the same temp outside? Has the on time crept up, etc.
Look at the other way - if the 6 units per day is correct for the same conditions as we have now then you were only using 4.6kW to heat your house (aasuming the old boiler was 70% efficient). That doesn't sound credible.
If the hot water tank is insulated then the heat loss from it isn't a lot. There's little to be gained from restricting the 'on' time other than hassle.
