Probably made on the same assembly line as Panasonic, LG, Daikin...But would you buy one of these? By "breezy air ltd of taiwan"?
I know, but its the respect people give the better names.Probably made on the same assembly line as Panasonic, LG, Daikin...But would you buy one of these? By "breezy air ltd of taiwan"?
I know.I know, but its the respect people give the better names.
That's why I'm planning to buy a second hand VW Phaeton.![]()
or half that for an unbranded unit off 'tinternet.
But would you buy one of these? By "breezy air ltd of taiwan"? I wouldn't, mainly because I'd be concerned about getting someone to actually install and service it!
GSHP by the specialists will run into £5000+.
Best way to do any heap pump system, IMO, is the tried and tested American way - ducting to each room, forced air. Balance the system with valves, like you would a radiator system, and a central thermostat. In the basement / plant room, then, you fit a single coil for the heating/cooling via a seperate heat pump. Only issue with this is the air return - you need a large return somewhere in the house, preferably the ground floor, which then pulls all the heat down from upstairs.
Kalirel is a responsive electric heating system that works on any "Unrestricted" electricity supplies, economy 10, or any other contracts, using only the exact amount of energy that each radiator requires.
The W12 is madness. I don't do many miles a year, so I don't have to get the diesel one, but even on the amount I do the W12 would be ruinous to run.Which is a luxury barge bargain, esp if you go for the w12![]()
Kalirel? Read from here onwards.gel filled radiators...
And they're all on the Russ Andrews mailing list.It's amazing how many people will believe that you can make an electric heater more efficient.
