If your supply and consumer unit are in different locations, you can always fit the SPD near the incomming supply.
I download the wylex CU catalogue the other day. Wish I hadn't lol
https://www.electrium.co.uk/brands/wylex
Note alot of these could be special order.
Wylex used to sell both flexible and fixed bus bars.
Fixed for example meaning you had to have 5 on one side and 5 on the other RCD.
Where as flexible meaning you could have 6 on one side and 4 on the other for example. If this suited you house better.
And as John said, high integ ones meaning you could also have some separate MCB or RCBOs. In this case it would have 3 neutral connection blocks inside.
I expect you will go all RCBO, or RCBO and one RCD but I don't know what they stock these days.
There is also a brand called fusebox. A cheaper brand which electricians seam to respect. Their RCBO's are significantly cheaper if you wanted all RCBO
