I have a snake scope (camera on 1 m flexible cord with light at end) and a cable access kit so I was planning on investigating the gaps and adhesive pattern once we have the house. Hopefully the adhesive is logically spaced and I have clear line of sight. Otherwise channelling it is
I was wondering if I could use a drill to make holes in the adhesive if there is no gap from the floor above. This may be a silly idea
The problem is that the developer would not grant access before completion to install cabling so I am faced with installing my AV cables with the least damage to our brand new house
The only problem I could see was getting power to a mounted TV in the lounge. The other Cat6, Coax and Speaker cables should hopefully go either behind the scirting and dot and dab downstairs and between the metal stud walls upstairs. My last resort is to break to outside and back in or to dig channells.
Cheers,
Gary
Cheers,
Gary
Cheers,
Gary
Cheers,
Gary
