Our flat is in a multi-storey building, with other flats above and below. The building has a common drain pipe that runs vertically through all the flats, in one corner of the kitchen. This pipe is grey plastic, about 10cm in diameter, and sits about 3 cm from the wall. In our flat, they have wrapped this pipe in fibreglass batts (glass wool, like insulation for new houses) and built a 30cm x 30cm enclosure around it.
We are redoing the kitchen and would like to reduce the size of this enclosure and claim back a little space. I'm trying to figure out how much extra space we could get. That depends in part on whether we need to leave the fiberglass in place.
Does anyone know why this drain pipe would be wrapped in fibreglass insulation, and whether we could remove it or compress it so it takes up less space? My best guess is that it is there to absorb the sound of water running through the pipe, but I'd be interested in other ideas.
