B
BigBurner
However if you ran the store on a timer you could have a 20 - 30 minute wait for hot water.
Not so in a Boilermate 2000. Thermal layering ensures that hot water is available within minutes. The boiler heats the cylinder top down, unlike a coiled cylinder which is top up. This ensures that useful hot water is at the top of the cylinder within minutes. The DHW plate heat X takes this hot water from the top and uses that. As the pump modulates it only takes what it need from the top of the cylinder.
Put it this way. If a 28kW boiler is coupled to a Boilermate 2000. The store is cold. You switch on the store. Go into the bathroom, undress and turn on the shower. By the time you have done this enough hot water will be at the top of the cylinder. Then the shower will be drawing hot water off and the boiler heating the top of the cylinder an the same time. This is "instant" hot water like an infinitely continuous combi.
I know there are timed versions but the basic principle of the thermal store is theat it constantly sits around 62 deg.
That is not the basic principle at all. You can time it to go off overnight and have it at running temperature during the on period.
The principle of a BoilerMate 2000 is to separate the heat generator, e.g. a boiler, from heat emitters (radiators) by a buffer (thermal store). This evens out the fluctuating demands for heating and hot water. By storing energy produced when the demand is low and discharging it when the demand is high, i.e. during property warm up or when hot water is drawn off, a smaller boiler can be used.
An important aspect of this concept is that hot water can be supplied directly from the mains at conventional flow rates without the need for temperature and pressure relief safety valves or expansion vessels. This is achieved by passing the mains water through a plate heat X. The outlet temperature of the DHW is maintained by a pcb board, which controls the speed of the pump circulating the primary water from the store through the plate heat exchanger.
A thermal store does not care how big the boiler is when it is couped "directly". The boiler will dump all its heat into the store giving a very fast reheat. 28mm flow and return pipes can handle approx a 70 kW boiler. A 50 to 60 kW boiler coupled to a Boilermate 2000 will supply three bathrooms providing the water flow and pressure is adequate. When a 50kW boiler is reheating the store it is the equivallent of approx 22 litres per min. The boiler and stored energy combine to give high extended outputs.
