GLOWORM 30CXI
5 Jan 2009
Manchester
Hoping you can solve this
My boiler has started leaking and after reading other subjects about this boiler I am begining to understand that it may not have been the best purchase.
Is there anything i can do to rectify this problem. I pretty sure its the condencing trap as i've read in other cases can this be fixed? there is no blockage i can see so It a strong possibility its the black tubes connecting to the condencing trap.
Here's hoping for a solution
Damo.
You need to ensure the boiler is out of the warrantee.
If so then you have to see exactly when the leak is coming from.
A clue will be that if its system water leaking then the pressure will fall.
If its condensate then it will only leak if the boiler is running. If so then it may be a nuisence but its not very serious.
There will be seals on the trap and it may be possible to refit or tighten something.
On these plastic boilers its essential to look with a very strong light to identify exactly whats leaking.
Tony
Thanks for your advise
It only leaks when the system is running and yes its out of its warentee i've have had a look and it seems to leak at the same time as water runs through a little pipe attached to the bottom of the boilers condensing trap to the outside drain. it looks like its the little ribbed black tubes connecting to the trap the seals could be defective but Im not 100% sure.
this one can be deceptive the rear flue seal on the back of heat ex can go and then start leaking condense, but appearing to come from the black plastic pipes, they also can crack and leak, so check carefully.
I will do. thanks again. whats the best way to check the rear flue seal....I guess its just a case of feeling for water.
Very common on these, especially those made about 2 years ago.
The new ones seem to have been re-designed to cope with this.
Any work in the combustion chamber is a job for an RGI. There are safety implications.
