glowworm energysaver combi, gc, 47-047-01
13 Nov 2008
Fife
toiling with this one,no power on display, 230v on x1-1 and x1-2 at 5 pin connector, both fuses i can see are ok, not sure how this boiler actually operates, where does the pcb get power from, is it the pcb interface x7, and do you still get parts for this boiler.
Have you checked the overheat stat. If this has tripped you will get no power at the neon or pcb. O/heat reset button underneath control panel. There is also overheat protection for the fan, but check the main one 1st.
