In my house because the garden is surrounded by houses all with PME supplies all I did was bolt the metal clad socket to the green house which in turn bonded whole green house to house PME earth.
However if the greenhouse was at the bottom of a long garden with only fields beyond then I would sink an earth rod and attach it to the frame and use a TT supply.
Thanks for those insights. Just to be clear, in the latter case, would you use only the TT earth rod (which is what I think I'd do) or are you talking, as I think you were earlier, of having both that and the PME earth? I would be interested in understand the thinking which brings you to those different approaches in the two situations - is it just because you feel an earth rod near to the houses would be within the resistance area of nearby PME earths, or what.
My house is closer to the 'fields beyond' situation. My greenhouse is around 35m from my house, and at least 50m, probably more, from any other house. As I think I've said, as things are I'm relying just on the house's (TT) earth, which is bonded to the greenhouse frame. I'd probably be slightly more comfortable with a local TT setup (isolated from the house's) - although I'm not entirely sure why! ... any comments?
The rest of what you write is all rather nostalgic. You write almost as if you know that I am, at least on paper, a radio amateur - although I don't think I've ever written anything here to reveal that! I say 'on paper', because it's literally decades since I was active, although I still have the licence. I got it in 1963 and (after the inevitable baptism on 'top band') my period of intensive activity ('misspent youth' - we had nerds even then!) was from then until the early 70s, nearly all on VHF/UHF (apart from HF contests). For here, I'll abreviate my callsign to G3S**, but I'd be delighted to fill the gaps in privately, if you so wished (can't really think why you would!). What you say about EMC makes sense, although it was called TVI in my day - and I remember having great problems which were eventually traced to diode action in rusty joints in guttering, just like you mention!
73, John.
