Electrical installation by guesswork, trial-and-error, hoping to hit on the right combination by luck, is a fools mission.
In that case this situation arises:I did that earlier & nothing happens the downstairs light does not come on with that wire removed.
you need to move the red link wire to either the blue or yellow. One, the light will be on all the time, the other, it will work correctly.if removing stop the light working completely, the red could be supposed to link to either the blue or yellow in that switch and not the red.
Yes, I realise that, but rather than luck we could employ logical deduction.Electrical installation by guesswork, trial-and-error, hoping to hit on the right combination by luck, is a fools mission.
hopefully not the same one as left you with that situationI have a electrician booked for next week to check all the jobs
he has done.
He should have checked all that before reenergising the circuit. If he is newly qualified, that should be all the more fresh in his mind.No he is newly qualified & very able
