L
LondonChap
I find it strange when plumbers recommend expensive complex ways of fixing the obvious.
What has been proposed is keep an old expensive to run boiler and installing expensive unvented cylinders and accumulators.
ATAG, an RR quality boiler, do a combi that will give 23.2 litres a minute. Five years guarantee.
http://www.atagheating.co.uk/defaul...&productgroepnaam=Combi boilers&productID=268
This is a new cheap to run top quality boiler and eliminates an expensive unvented cylinder and all those accumulators. The cost cannot be any more than those cylinders and keeping the old gas guzzling boiler. The pressure and flow is fine for a combi as long as the pipes are sized and run right. Replacing an old mains tap can improve flow. Having the cold water feed to the combi 22mm improves matters as well as the above post states. Then he has mains pressure all around and a nice big space in the airing cupboard as the big cylinder is now gone. A small radiator can be fitted in the airing cupboard if heat is needed.
I would look at a big quality combi as the first option which gives a new cheap to run boiler (energy is not getting cheaper) and mains pressure hot water at high flow and pressure rates. The combi also will not run out of hot water, important with teenage girls, and gives hot water for ever. Why do people do things the hard way?
EDIT: 23.2 litres a minute gives 696 litres in 30 minutes. That is a big cylinder to hold that amount of hot water. In 15 minutes that is 348 litres of hot water delivered. A 350 litre unvented cylinder very big and very expensive.
