1st of all hello, forgive me if this is a long 1st post but it driving me nuts, I believe I know answer but keep being by installers I’m wrong
Last year my 1 bedroom ground floor flat had new central heating installed , and it’s been bloody freezing ever since , they have check TRV , room stat against a digital thermometer ect ect all is 100% , They told me the WHOLE flat was designed to heat to a min 21c , yet even with it on all day it’s never above 15 worst when it’s really cold , yet by my calculations they about 25% UNDER BTU need of rads , the boiler is shutting down on return temp of water and longer its left on the more it shuts down , I have set every TRV to max and boiler to max . Still will not heat flat
The system is a new Valiant ecoTECplus 824; rads are Stella with Honeywell TRVs
I’ll give you 2 rooms and see what you think, the flat is council of older design, has solid uninsulated concrete floors, the walls are 4inch brick dry lined the double glazing is pre 2002 and don’t work very well, the ceilings are concrete again uninsulated, party walls are 4inch dry lined each side, with no heating on in flat the floors can get so cold you can feel damp on them and the condensation actually freezes on inside of windows when really cold
Living room is 15x11x8, one outside wall that’s is almost all glass, door and big window they have fitted a Stella Rad with btu of 5145 in middle of longest wall
Bedroom 16x9x8 2 outside walls one 16 and 1wall 9 half taken up with a window rad is under this window they have fitted a Stella rad 4589btu
Hall is 10x5x8 with front door direct to it and an unheated kitchen of same hall that’s very cold and have fitted a stella rad of 1525 btu in hall and nothing in kitchen
So either they not taken in account my variables, or based there calculation on a moden well insulated property as all of the basic calculators I can find suggest my rad are 25% under at least , the installers insist they worked it all out to correct BTU but refused to supply calculations and if im cold call council , council says to call installers
Thanks for your time
Tezz
Tezz
