Hi everyone
I know there are quite a few threads already about this, but I can't seem to find one that matches my experience.
I know my boiler is old, over 20 years since it was fitted, it was brand new, and over the years it has had almost everything replaced, but I still get lock outs very often, even after being serviced, and has been doing this for quite a few years now.
Description of the fault is:
It will fire up and run until everything is up to temperature, but when it needs to fire up again, it locks out.
When resetting, it goes through the start up process, clicks once when attempting to fire, then locks out.
I can, sometimes, get it to fire up after resetting 3 or 4 times, yes I know this isn't advised, but what I have found works almost every time, is to leave it a few hours before resetting. It will then reset, but repeats as above, it runs until everything is up to temp and when it needs to fire up again, it locks out.
However, sometimes it will run fine for a day or two before doing this.
Quite often there is also quite a strong smell of the kerosene when it trips.
I am wondering it is a fuel supply issue, too much, or not enough, although there isn't a way of regulating how much oil it gets as it is gravity fed from the tank to the fuel pump in the boiler.
Has anyone else experienced this?
