Howdi all
Havent been on for a while but have a new project on the go and could do
with some plumbing advice from the pro's.
I'm fitting a new bathroom and want to plumb the toilet and sink waste pipes under the floor as i hate boxed in pipes etc. I like everything
hidden with nice clean lines.
I aslo want to swap the toilet and sink in opposite positions to maximise
space .
Some pics below that will explain a bit more detail
Bathroom stripped out. You can see where the toilet was originally looking
at the lines on the floor
Waste pipes going to outside wall
Outside view of the pipes
This is the new layout that i want
The toilet base and sink pedestal are flush fitting to the wall so there is no room for passing waste pipes etc hence why i want to sink everything into the floor and what i want to know is, is this DO able ???
Luckily the joists underneath run the same way as the toilet waste pipe
so there will be no joist cutting involved, just running along side them.
Also been scratching my head on cutting another hole in the outside wall
as i will need to drop everything down a foot or so but thought could i not
come back up to the original pipe under the bath using a flexi pipe or
u-bend but then thought this would cause blockage problems ???
Has anyone else done this ???
Any help and info would be greatly appreciated.
Got the tilers coming in next monday so need to get my skates on haha.
cheers
Kris
space .
cheers
Kris
