It's far better if the wastes connect into the top section of the soil branch rather than the sides. I would take the basin waste straight down behind the pedestal and directly into the soil pipe with a single solvent weld boss like Multiquick Easy Boss. Do the same with the bath waste in a convenient location.http://www.multikwik.com/products.php?keywords=easy bossFacilitating easy installation, Easy Boss requires no straps avoiding the need for all-round access to the soil pipe. It can simply be fitted into a 57mm hole and is ready to receive a 1¼ or 1½ inch push fit pipe. For 40mm solvent weld requirements the seal is simply removed and the pipe glued in place, and for 32mm versions an adaptor is supplied as standard.
Ahh cheers pal your a star
Something like this then ??
Would this system not cause a terrible smell to come through the plug
holes with it being linked directly to the soil stack ????
City Plumbing down the road have them in stock so will go grab 2.
While im at it should i replace all the bath & sink waste pipes (They stink) or should i flush them out clean the best i can ???
It looks like all the joints are solvent welded, is this better than push fit system ???
Is there anything else, looking at the pictures you think i will need ???
cheers
Kris
