Which implies that you can...[/quote](1.18 Document H) Branch pipes up to 40mm diameter joining branch pipes 100mm diameter or greater should, if practicable, connect to the upper part of the pipe wall of the larger branch.
You can’t just quote that single clause in isolation as proof that it will work. There is still a requirement to maintain a minimum of 25mm in all traps under all conditions & for the provision of ventilation to prevent siphoning as & where necessary; if you follow good design practice it’s never a problem!
I’m bored with this, it's like sticking pins in your eyes; Chris you’ve got mine & a couple of other opinions, decide for yourself; or better still phone your LABC & ask them; but if you do, post back what they say!
