ignore morrismini
keep the megaflo
keep the megaflo
<an expression of disagreement>
It's a fact that Gledhill Water Storage Limited is no longer trading.<an expression of disagreement>However, those aren't made anymore. The company that makes the Pulsacoil BP has not gone bust, and is still trading.
Both of these are statements of fact, not opinion.<an expression of disagreement>The BP uses no special parts except for a blending valve, and even if this isn't reliable it's incredibly easy to replace.
All statements of fact, not opinion.<an expression of disagreement>The only reaonsable doubt is over the quality of the cylinder, and I've fitted plenty of indirect Gledhill cylinders that have turned in many years of service, so I don't have any personal reason to doubt the BP cylinder.
All fact, not opinion.<an expression of disagreement>The internal coil will scale up in a hard water area, but if you fit a polyphosphate based scale reducing device, such as the Aquadial CombiCare, then you can hugely extend the interval between descalings.
This is my opinion, and an attempt to be helpful to the OP. If you have a different opinion, or a different way of being helpful, then please go ahead and post your information.<an expression of disagreement>Check the blurb you were given before and during the purchase of the flat - if you have anything in writing regarding the Megaflo, then you should be able to get the builder to accept a condition to provide the same length (25 years) of warranty for the Pulsacoil, just in case Gledhill doesn't (and I'm too lazy to look it up on the Gledhill web site).
Could it be here?Goldberg, Where has the OP stated that the intention is to fit a Pulsacoil?
I think it could.To resolve this, the building company has ruled out replacing the pipework because it would be costly and very difficult for them, and instead wants to replace the unvented Megaflo boilers with Gledhill Pulsacoils, a different type of system.
He merely did not.He merely stated that the builder intended to fit a Gledhill.
I fitted Claudia Schiffer, Cindy Crawford, Kate Moss, Linda Evangelista, Naomi Campbell and Christy Turlington.So which models have you fitted?
Sorry dude... Not impressed. I was there before you.
Hmm. Well, there certainly used to be, but now there's just the one.There are a number of different Pulsacoils
I know that there's only the one. How many do you know that there are?being an installer you would know this.
Indeed it does. And so too does the Pulsacoil 2000. And the A Class.For example, the Pulsacoil 3 has a PCB.
I can't, because he didn't. However, I never said that he did.Now please show me where the OP stated that the unit to be fitted was to be a BP
All the OP needs is a time machine to go back and buy a new one.
So, just to recap for the benefit of the OP, you wrote this:I don't think that I need a time machine, there is still plenty of old stock available.
...and then didn't offer any more information on Gledhill products, until I wrote this:I Thought that Gledhill had gone bust.
And then, despite both of knowing that Gledhill had gone bust, you decided to chirp up with this:I suspect that many people who are dissing the Pulsacoil are thinking of the over-complexity of the units that had an external plate heat exchanger and an electronic pump speed control board.
...implying that you had it in mind all the time that the OP's builder could buy and fit a product that isn't made anymore, that was manufactured by a company that ceased trading more than a year ago, and that has no manufacturer's warranty.Goldberg, Where has the OP stated that the intention is to fit a PulsacoilBP?
...you're suggesting that the OP's builder could use a product that became obsolete more than 10 years ago.There are a number of different Pulsacoils ... For example, the Pulsacoil 3 has a PCB.
OP Here. Thanks all... so I will fight like hell to keep the megaflo but I'm getting desperate here purely because I can't find any options that would enable me to keep it. Its all so stupid... all this just cos someone fitted the wrong pipe
The Hep valve was a great plan but it has been ruled out by the builder cos the soil stacks are apparently standard plastic - unless someone can suggest a workaround for that. Can't replace them throughout cos its a 4 storey apartment block and they are in the walls etc.
We're still under NHBC warranty but the NHBC will be happy to accept the Pulsacoil as a replacement as their concern is meeting their standards rather than providing like-for-like quality.
Any more ideas? Maybe there's another type of boiler that would be better than the Pulsacoil as a replacement for the Megaflo. We need something appropriate for the structure of our building, with good quality design and high pressure. Any suggestions? Sorry to come back with more questions.
Cheers again everyone! VERY helpful .
