I think the lights go dim because its meant to be a 3 phase motor, converted to run on single phase with a capacitor to provide the 3rd phase. Someone may correct me though, I'm no expert.
Actually, it is quite easy to do with a switch - and you call yourself a sparky ?You need to change the position of two links between four terminals.
It's not so much the magnetic field as that'll be established within one mains cycle. It's the high current taken by a motor until it's up to speed and the back-EMF acts to counteract it (simplifying things a bit).The lights dim as this is an inductive load, and when you first power it up, it is effectively a short circuit until the magnectic field gets established.
Agreed.This is known as inrush current, and is normal.
This motor isn't really suitable - unless it run above a certain speed then the start winding will be in circuit and it'll take an excessive current and probably burn out (or blow the CFD, or blow a fuse). If speed control is wanted, then it's best to get a 240V 3P motor and one of the small (sub £100) inverters which are normally designed to drive 3P motors. A capacitor run (not start cap & switch) would work, but last time I looked, there weren't that many CFDs designed for single phase motors - I recall looking for some a while ago to run (with remote/computer control) some 1P fans at work.The only way to speed control it would be to use an invertor. This gives you infinately variable speed, soft start, so no more dimming of your lights, and forward and reverse control too.
The motor will be taking a lot more than its rated power until it is running at full speed. Depending on type of motor the power taken at standstill can be more than ten times the rated power.Note: Kettle, 3.5kW, does NOT dim the lights.
Correcting myself now I'm awake2P C/O with centre off would do it, though really it wants to be 3P so the live can be disconnected as well rather than just switching the neutral (or swap L & N so the 2P switch is in the live). Ideally the 3rd pole would be make last/break first so the power goes off before the windings are switched round.
Are the white wires labelled S1 and S2 ?
According to the diagram given by the OP, they are connected to a centrifugal switch for starting.
When the motor is not running, the switch labelled K on the left of the diagram is closed. When power is applied, additional power is applied via the starting capacitor (Cst) to give better starting torque. As the motor runs up, the switch opens and only the running capacitor (Cr) is used to help provide a "third phase".
I need to take a better look at the diagrams when I'm actually awake - they don't quite make sense as the difference between CW and CCW wiring isn't just reversal of a winding.
Yes.Am I reading the diagram wrong?
No.As I see it, you are not changing the positions of the links, merely removing them for a change of direction.
