possibly correct. But as of today, faradayski has seen zero failed crimps and 'some' failed screw terminals, so although you might possibly be correct, you could equally be incorrect.
I agree that it's difficult when one of the figures is zero - but I presume you must accept that crimped terminals must fail sometime, so the fact that you have yet to see even one is inevitably a consequence of the limitations of the extent of exposure of any one electrician.
Given your admission that you are not a practicing electrician, i would be wary of relying on your personal point of view as any kind of basis for dreaming up statistics - just say what you see (or have seen)
Saying what I have seen would not be helpful to this discussion, since my exposure is inevitably very limited - and I'm certainly not suggesting that anyone should 'rely upon my opinion'. Indeed, I have acknowledged on many occasions (including today) that my opinion about crimped joints is 'out on a limb', but that doesn't alter the fact that it's my opinion.
Hmm, not 100% convinced by that. JBs tend to be used by anyone who chooses to connect two wires together (skilled or otherwise), crimped joints tend to be the reserve of sparkies (hopefully skilled), so im not sure the human factor is even for both.
I didn't mean to imply that it was. However, you presumably don't deny that screwed joints made by electricians have been known to fail, and sometimes even because of 'human error', and I was merely pointing out that human error is also a potential factor with crimping. You presumably also acknowledge that there are some electricians who are less skilled than one would hope - witness some of the stories one reads here, and everywhere else.
Decent crimp tools are have ratchets, so they should give a correctly squished joint time after time,
As I keep saying, I'm less than convinced by the design of ratchet crimpers that most people seem to use; the ratchet, per se, doesn't seem to add very much to the equation - and, as I keep saying, I personally regarded single-plane squashing of a non-slit crimp as being conceptually iffy.
I imagine that some thought went into the regs(although some might say 'not enough') and those who wrote them had some reason for their choice of what was reasonable and what wasn't.
That must be true, but it doesn't stop me being astonished at what they decided - particularly given the unknown of the level of skill of the person who made the crimped joint before they rendered it inaccessible. Many aspects of the regs are, understably, verging on the over-cautious. In relation to this issue, they seem to have gone to the other extreme, for whatever reason.
Kind Regards, John.
