help with ring main
20 Mar 2012
Kent
little help please people....
Ive decided to put a lighting circuit and a ring main in my shed off a new consumer unit which i finished today. lighting is absolutely fine but for some reason my sockets are staying live even when switched off. i plugged in a martindale thingy and its showing a L&N fault.
Ive checked the consumer unit and a few of the sockets and they are wired right so what can the problem be?
Everything.
Specifically your new CU, the feeder to it, the meter / intake position and the back of one of the problem sockets.
Sounds like incorrect polarity at the new consumer unit or supply to consumer unit. Try checking the polarity with a proper voltage tester or multi meter.
Ok yeah i can do that tomorrow. I just wanted to know what the possible fault may be so that I can check?
The feed for the shed comes from a 6mm 3core swa from a henley block in the house that's all correct and the cu is wired correctly so I was just asking what would I check next? Is it possible that just one socket is wired wrong to cause all the sockets to have this fault?
Ring final circuit in a shed - this has got to be a wind up.
Definitely a wind up - I mean what idiot would power up a consumer unit without first of all conducting the proper dead tests to establish that he had continuity, insulation resistance, polarity.
What type of earth have you used?
Why would it be a wind up?
Sorry im no electrician but i can do bits around the house so thought id have a go at this. i was just asking for a bit of advice over where ive possibly gone wrong?
Everything.
I'd also like to see a photograph/scan of all of the results of all of the tests that were done before and after energising.
I mean what idiot would power up a consumer unit without first of all conducting the proper dead tests to establish that he had continuity, insulation resistance, polarity?
The sort of idiot who is so ignorant and so stupid that he does not see why his ignorance and stupidity should in any way whatsoever be a bar to him fiddling with things which he doesn't understand.
I don't suppose he's met the legal requirements for what he did either.
ok so obviously some friendly advice is not going to happen here just abuse. thanks guys ill figure it out myself.
