Hi all, been a while. I'm installing a power supply to my dettached garage. I have installed the cable from consumer unit to garage and my electrician friend will be checking this over and attaching the cable at the CU and garage ends when he gets back from holiday.
Couple of questions to hopefully save some time -
1. I understand that the protective wiring in SWA cable has to be earthed at at least one end. I have put the 'banjo' of the gland inside the plastic junction box, and wired it to the earth wire in the 3 core SWA (black wire). Is this acceptable? If not how should it be earthed?
2. I have a 2 way garage unit for the garage end. What do I need to buy for the CU (house) end? It's an ancient fusebox with no circuit breaker switches. I understand there has to be RCD protection at the source, so do I need another unit for this end?
