- Joined
- 10 May 2005
- Messages
- 4
- Reaction score
- 0
- Country
NO 1. looking to install a shower unit about 1200 x 900.
any opinions on reliable makes and suppliers of a sliding door for the above
NO2. I am replacing my toilet system in my bathtroom and when I come to fit new pan the plastic soil pipe going out yo the stack is too short can I extend this pipe or is it a push fit into stack and just nees replacing with lonber piece?
NO 3. when performing a safety check if the gas fire was removed for a flue check and the closure tape needed replacing would you tell them that it needs servicing or replacing the tape is part of the safety check.
NO 4. i've just had a newish hot water cylinder fitted by a qualified plummer (allegedly) he had to fit new couplings etc. now every few days the hot water goes cold, to get it going again i drain of a couple of pints from the drain valve outside and its ok for afew days.c/h works ok.boiler is 6 years old, the hot water is gravity fed from boiler(cylinder directly above)old cylinder had larger bore fittings,boiler is a IDEAL classic. Had a problem with pump sraight after plummer left, impeller came of motor.after he suspiciously adjusted pump on his way out through kitchen,(coincidece) thankful for any advice By newish less than 6 months old. mate had new combi boiler fitted.
NO5. I've got an ST55 waterpump that works a toilet cistern, 2 sinks and a bath/shower. They are all within 20 feet of the pump. Last night it stopped pumping hot water. There is no problem with the cold water. (yet) The flat is 4 years old so the pump is probably 5 years old. I was wondering if anyone had any tips, is there a reset button ? is it handy to service ? can I get a replacement in Dublin ??
